Where Are The Adjuster Screws To Adjust Low Beam Lights On The Mk3?
mpg_junkie
Hi all,
I have had a good look under the bonnet and searched online, but cannot find where the adjuster screws are to adjust low beam lights on my mk3 yaris (2012). The adjuster motor is set to 0 but beam is still far too low. Any guidance gratefully received.
MPG junkie
Take it to your main dealer - should be covered under warranty and will then be setup correctly rather than with guess work,
I'd agree with that. It may actually be a fault with the remote adjustment system, so worth an ask.
