Couple Of Issues With My 03 Yaris
jayrlopez
Hello guys I've got some issues with the car that need to be addressed and was hoping if you guys can help. I've got a 03 reg 5 door yaris. Problems include:
Front passenger door lock not locking anymore
Rear washer stopped working
Rear wiper needs to be replaced (I tried replacing it without knowing that I only needed to change the rubber bit and broke the plastic bit)
Exhaust needs replacing
Front driver's side door needs replacing (open to suggestions on where I can find a second hand part)
I'm hoping to have these fixed within two weeks apart from the driver's side door.
The door locking and washers have been covered recently,for the exhaust seriously consider having it done for you fitting an exhaust without a ramp is a horrible job.For the wiper if you mean the wiper head pull the end of head nearest the spindle away from the arm and it will unclip, when refitting make sure the little plastic tang dose not snag on the edge of the hole,very little pressure should be needed.. If you mean the whole arm you need to use a puller (about £10) after removing the nut
