Abs Light
bigron
every now and then my abs light comes only if you only just touch brake the light comes on- if i stop engine then restart restart light has gone off but if i brake normal light dose not come on only happens if i touch brakes lightly can you help thanks big ron
found problem fitted new brake switch the one on top of brake pedal fitted no more ab lights coming on [GREAT] SWITCH COST £30 pounds from Toyota dealer. Car model Rav 4 2006 [ HAD CODE C1249]
