Blue Tooth
RonBin
Is it possible to register two mobile phones for Blue tooth usage. My wife and I both have an iPhone. Mine is registered and works but can I also register my wife's so she can use it without having to make any adjustments to the settings?
If I have come to the wrong Forum, please forgive the error and forward the request to the correct one.
Thank you.
ronbin
Is it possible to register two mobile phones for Blue tooth usage. My wife and I both have an IPhone. Mine is registered and works but can I also register my wife's so she can use it without having to make any adjustments to the settings?
Thank you.
ronbin
You can, but it'll only link to one phone at a time I believe.
For example we've a family of 4, all of our phones are registered, so which ever one is in the car on start up will link for handsfree calls.
Hi Ron, i have a Rav 4 with 2 mobiles on it but as said above the car will only work for one, presumably the drivers. You have to 'tune' the different phones into the cars bluetooth and it is easy to switch from phone to phone just using the on board display. If left untouched the car will by default go back to the last phone that was blue toothed to it.
Regards
Thanks for your reply, very much apopreciated. So, if there is only one of us in the car, it will switch to who was ever in the car, but if there eare two of us in the car, I would have to switch manually to either my wife or myself as the case may be.
I will have a fiddle with the screen and see how I get on.
Thanks again,
ronbin
