Running Rich! Toyota Corolla T Sport 1.8 Vvt-Li
Hi everyone!
I have been having a few issues with my car! It seems to be running rich (judging by the plugs being black and the strong smell of petrol). It has always run slightly rich since I owned the car. it also revs at 1800RPM from cold. at idle when hot it revs at 1000.
the fuel issue got much worse when I fitted an aftermarket K&N air filter.
When i fitted the K&N air filter it threw up an engine code (P0172) System too rich. it also had a couple more problems that go with this.. the engine would bog down in the lower revs while pulling off, hesitating.
Since I put it back to standard the engine management light has gone off. but it still runs rich as always! so I did the following things:
Cleaned the MAF sensor, checked for increase/decrease.
Checked the O2 sensors had a voltage reading (12v) and ohm reading (16 OHMS)
Checked for any Vacuum leaks.
Checked Oil Level
Checked Coolant level
Bits I haven't Checked:
​Throttle Position sensor (TPS)
O2 sensor Readings
MAF Sensor Readings
Coolant Temp Sensor Readings
If anyone has any advice on this it would be greatly appreciated!
Thanks Dan
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
