Aygo Pdf Manual - I Need To Change The Sidelight Bulbs!
Hi Folks :euro:
I've just purchased an Aygo + 2006 and the side light bulbs have stopped working :fox:
Is there a PDF manual that anyone can kindly mail me please or instruct me how to change the light bulbs.
Many thanks,
Josh :euro:
The following link enables one to download an electronic owners manual for the 2012 Aygo - https://www.toyota.co.uk/tme#/my-toyota/eManual
Would imagine the sidelight fitting will be similar for earlier models.
The sidelights come out quite easily. Just twist the holder and pull. I found it much easier to leave the wiring connector in place while changing the bulbs. When you've finished, just pop the bulb through the hole in the headlamp assembly and twist the holder in the opposite direction and it'll lock into place.
Cheers...your advice was spot on. Thank you
Excellent advice....worked a treat...Thank you
You're welcome, glad I could help ☺
