Dash Cam Recomendation .....
Exvec
Quite simply that,?Anyone recommend one my top price to pay would be around £50 tops..Thanks in Advance.
Interesting question. I was wondering if anyone knows of one that's compatible with an iPad? I've had dash cams in the past and all gave up the ghost within six months or so. I used to drive for a living so they were used all day every day, so I have to take that into account, but the reality is, most are the usual Chinese tat that breaks within months rather than years. It's the reason I like Japanese engineering. I have some vintage Japanese hi-fi separates and the quality is beyond anything you can buy today. So does anyone know of a good quality Japanese dash cam?
afaik most of the really good dash cams come out of S.Korea (don't ask me why :dontgetit: ) but you will pay many times £50 for the current ones (the CF-100 used to be £150-200).
I wonder whether they're Japanese designed but made in Korea to reduce the cost?
I have a 'Nextbase' in mine for over two years without any problems and quite happy with it. It was £52 then & seems a popular make. Have a look in Halfords as they stock them. I did not buy from them tho' I have it semi hard wired without any wires showing at all and comes on with ignition.
The Which? Best Buy that was under £100 was the Transcend DrivePro 200 at around £80
& his website is http://www.techmoan.com
One of the nice things about the CF-100 is that it has a proper buffered parking mode if you want that but on an Avensis to take advantage of that you will need to hard-wire it & strongly recommended to use a Battery discharge protection device (so more money ~£25). If you want to add GPS it's an add on (Morgan Computers has it for ~£20 delivered).
If you don't want the rear camera of the CF-100 Morgan Computers has the CW-100 (essentially the same as the main CF-100 unit) for £40 (& you can probably find a 10% discount code).
Thank you all for replies,there plenty to chew on there,i actually need the cam for my works van not my Avensis,after Some div nearly wiped me out in Brum last friday anyway its a start .
