Hi.
My CD unit has stopped working. I have checked the fuses and they are Ok, the cigarette lighter is still working. I am having trouble finding a replacement with the same model No ( 58816, printed on front of unit ). Does anyone know if any other unit would be compatible with my faulty unit, I think some have different wiring at the back. Many Thanks. Peter.
Do you mean just the CD drive has stopped working or the complete radio /cd unit ?
The Haynes manual shows several fuses feeding in to that unit, the 15A Cig, 15A Dome, 10 ECU IGN
As well as searching this Corolla forum, there is a specific Toyota Audio forum where you might also find an answer.
http://www.toyotaownersclub.com/forums/forum/19-audiovideoelectronics/
If you cannot find an easy fix for your unit, you might be able to find a second hand one for sale as many members remove their stock toyota unit and fit more modern units.
( you do loose the mpg display, but its never that accurate and its not really used, plus a modern unit can be bought with all the modern usb etc interfaces that are very difficult to add to the stock unit. )
There are lots of places selling standard head units, single or double din and these can be supplied with a suitable surround to fill the void and the necessary adaptor cables for the head unit and steering wheel controls, if fitted.
eg http://www.caraudiodirect.co.uk/install-adaptors?cat=594
Thanks for your help. It is the unit that is not working, I will take another look at the fuses. Thank you for the Links.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
