Engine fan running with ignition off. No fault codes on obd
Disconnected the fan and it's still draining my Battery . I replaced coolant sensor and still have problems. Any ideas would be great.
From a 2004 manual, might not be exactly the same wiring as your model, but should give you a good idea what to look for.
post-95973-0-75712700-1447536356_thumb.j
post-95973-0-16446300-1447536365_thumb.j
post-95973-0-40902400-1447536376_thumb.j
