Anti-Trap Windows
Toyota_Auris_Hybrid
Hi again
new topic
I have noticed that my 2010 toyota auris anti-trap windows dont work and how do i set them up?
Do you mean the auto open/close? Hold the button for 10 secs after the window is fully open, and after fully closed.
hi alan
many thanks
the auto windows work when i press down and automatically goes down and like wise for up... the anti trap is when or if you put your hand between the window/glass and as it goes upit should stop and drop back down as it senses that something is in the way or to stop someone from having there poor hands/fingers from getting trapped... unfortunally i have noticed that mine is not working and want to know if there is a setup or something wrong.
1. The anti trap only operates on windows with "auto" function
2. The anti trap does detect an object in the window aperture the window motor detects excessive resistance as it closes and will stop and drop a bit, if you place your forearm in the window and auto close it either push down on the glass or wait for it to close on your arm to test the anti trap ( just mind as may pinch a bit if you let it close on your arm !! )
