Hello!
I have a 2010 Aygo Black, only had the car 6 months and the green arrow for the right indicator stopped working today. It's my first car so I am clueless!
The actual indicator itself works, just the green arrow inside the car.
Hi Kimberley & welcome to the forum :)
possibly just a bulb failure in the dash - not sure how easy it is to get to on an Aygo though..
  • 3 years later...
Hello Kimmik, I know this is a complete shot in the dark but I also have a 2010 aygo and my right turn dash indicator worked for a while then stopped and now is trying to work but is really dim. Did you manage to sort yours out and if so can you give me any advice. Thanks John.
Try a very light thumping on the plastic part above the bulb. It might restore a loose connection. My old Corolla did that after 15 years of service and I was almost prepared to strip down the dash to get at the bulbs but light thumping restored the connection and no more problem.
Thank you for the reply. I will try a light thumping with my 2lb lump hammer.... Haha seriously I must admit I've already tried a bit of knocking here and there. No joy. I've decided to take out the instrument cluster and trace the wiring as far as I can. I have a circuit tester and I'm learning how to use it. If all else fails buy a second hand cluster and hope for the best. Its a real headache. Thanks again.
  • 10 months later...
Hi did you get this problem sorted ? I have same problem
  • 2 months later...
Does anybody have answer?
  • 11 months later...
  • 4 weeks later...
Did the repair by Revtronic work?
Yes 👍
