Eco System
jaarde
Presumably you mean the 'stop-start' system
The stop-start system will operate when the following conditions are met:
* the engine is adequately warmed up
* the Battery is sufficiently charged
The following may affect operation of the stop-start system:
* engine coolant temperature is extremely high
* air conditioning is being used when the vehicle interior temperature is high
* air conditioning is being used when the outside temperature is 8 degrees C or lower
* (for vehicles with automatic air conditioning only - ie climate control) the windscreen demister is being used
* the Battery is not sufficiently charged
* due to traffic or similar conditions, the vehicle is being stopped repeatedly
Moved to the Yaris club
