Avensis T180 Rear Brake Light Bulb Change
bogyotuv
Hi. I'm in need of some help how to change tail brake light bulb, if anyone knows please share your experience. I could remove the light itself but can't get the bulb in its place.
Please help
Its awkward the first time round. There are two tabs that need to pressed then the rear bulb holder comes away. Then push and twist the faulty bulb anti clock wise. If you want to remove the whole light cluster its held on with 3 10mm nuts
