Corolla 2003 1.6 Vvt-I 3Zz-Fe 81 Kw Motor Stops
Hello,
I'm new on this forum, but i have the following problem on my Corolla 2003 1.6 VVT-i 3ZZ-FE 81 KW gasoline : i don't know why and how- sometimes my car stops running and the speed and rps dashboard is turned of. I have power on the headlights, stereo, central console. I pulled on the side of the road, tried to start again the car- the car started without any problem. No error in the dashboard.
I visited a local mechanism (for a diagnose) and told me that a have a faulty lambda sensor #1, the throttle body is not fully open when i press the throttle pedal ( i changed the TPS sensor) and also the fuel pomp is slightly worn out( the minimum pressure is slightly bellow of the normal).
Do you have any ideas for this behaviour?
Thanks,
Lucian
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
