Vsc And Trac Control Light On Running Out Of Options
Recently had the VSC and TRAC light come on solid on the dash board, I have attempted the following but no success any other ideas.
. Discount Battery 1 hour at least
. OBD test found no faults
. Checked all fuses, all good
. Bridged out pins on obd as suggested via you tube still no luck
We have recently replace the passenger side driveshaft but that was 2 weeks ago and the light has just come on the last couple of days.
Any ideas guys, thanks in advance
If there are lights on then there will be a code stored however it appears your OBD reader cannot obtain it, I would suggest you need someone with a fully compliant diagnostic machine such as a Toyota dealer or Toyota specialist.
  • 6 months later...
FJ cruiser 2007 when all four Christmas lights came on I replaced master cylinder because of abs brake issues which is the most important than all of other things anyways after fix it then the other three still on VSC and Trac and Skid lights left to go I learned that pep boys claimed it has something to Do with master cylinder solenoid that related to VSC Trac and skid . Need to pin point to which parts I need to buy ..... The code cost you 80 dollars or more then have to buy parts or maybe have to pay for labor which is rip off at least if you know how to use your head as a mechanic is waste lot of money. Just do it at home. Image1465577860.994845.thumb.jpg.99efc30Image1465577876.087643.thumb.jpg.1637a34Image1465577891.817857.thumb.jpg.f009bedImage1465577908.647038.thumb.jpg.c2fb693
Sent from my iPhone using Tapatalk
