2Ad-Ftv Charging Electrical Wiring Diagram
paulbrads
I am looking for the Electrical Wiring Diagram for the charging circuit on an Avensis Mk2 2.2 D-4D 2008 2AD-FTV if anyone knows where I can find said document I would be very grateful. I have checked toyota-tech website and found the following circuit diagram which was under the area for 2AD-FTV but it doesn't have the engine code on the diagram! Can anyone advise if the charging circuit is the same across the models?
charging circuit.pdf
I also found this diagram:
post-151602-0-62376300-1449413101_thumb.
It would also be nice to obtain a description of the charging circuit including method of checking the system.
If anyone has any experience with this I would be very nice to hear from you.
Cheers
Paul
