Stearing Wheel Blocking
Issamos
Hi guys
I have a yaris 2006. Sometimes I feel the steering wheel struggles for while then everything return to normal.
What do you think?
Sent from my SM-N7505 using Tapatalk
Not sure what you mean, need more info.
The steering wheel feels sometimes sticky and not smooth when turning it.
On a 2006 Yaris the power steering is electronicly assisted sometimes a weak/failing Battery or faulty alternator can give a intermittent lack of assistance which gives a stuttering/unsmooth sensation when turning the wheel
On a 2006 Yaris the power steering is electronicly assisted sometimes a weak/failing battery or faulty alternator can give a intermittent lack of assistance which gives a stuttering/unsmooth sensation when turning the wheel
Hi Devon
I mesured the Battery voltage and it was 14v. Could there be an other issue?
Check the auxiliaries drive belt.
In the past I've had something that sounds similar while parking (though I'm not certain now if the was our Yaris or a previous Honda). The extra load on the alternator from the electric p/s made the belt slip and reduced the power available. On examination there were quite a lot of chunks of the grooves missing through wear and tear. New belt sorted it.
The belt is in very good condition. In fact, the problem occurs after driving for a while and not when the car is cold. Sometimes I can hear a clic when turning the wheel but not all the time.
