hi
is there a how 2 on removing the boot side lining, want to take it off to check a few things, but looks very stiff and scared to pull it just in case it breaks
All the panels I have come across are held on by plastic pop fittings or clips moulded into the panel and sometimes the odd screw.
Its just a case of carefully feeling around the panel and carefully using a stout blade to pop them out.
You can buy proper tools from car shops / Machine Mart, though most use a big screwdriver.
You will doubtless damage some of the pop fittings, again you can get similar new ones from most shops or the real thing from Toyota.
post-95973-0-72303000-1449918709_thumb.j
thats great, thx
