2002 Corolla Verso Auto Transmission Does It Have A Sensor
My 2002 Corolla Verso automatic is occasionally slow to change up to overdrive, if I switch overdrive off and then back on it immediately changes up. This is an intermittent fault. Does the car have a sensor that may be faulty. I have changed the engine temperature sensor but this did not make any difference. It has been suggested that the car has an ATS ? auto transmission sensor, anyone know if this is correct.
I have a 2004 Corolla 1.6 vvti with auto transmission and have found that the gearbox won't go into overdrive until the engine is warmed up. In colder weather this may take a bit longer. I think it might be some kind of fail safe.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
