2010 Toyota Avensis
alagbe
Moved to the Avensis club
I have had this 3 times since I got the car in September. It happens just after starting when moving off with the steering is turned. I just stop the car and restart. All is fine after.
I plugged my diagnostic Launch CreaderVIII, and retrieved code C1288 - ECUs do not match or something like that.
At a guess the ABS and TSC ECUs failed to communicate properly during initialization/self check. There may be a loose or intermittent connection.
I erased the DTC and all is well.
