Hi there,
I'm new to the forum and have a 2003 Corolla. It has an SRS light illuminated on the dash and when I've bridged the diagnostic port to give me a flash code, it returns 7-2.
I'm struggling as to what this could be. Does anyone have any ideas?
I've tested the pre-tensioners and I get a 2.2ohm reading on all, which to me indicates that they are working and haven't fired in the past. All plug connections seem plugged in and free from dirt/rust/water ingress.
Any help would be greatly appreciated :)
Mikeyb123
Not your exact model, its a LH drive, but should give some general guidance with the codes.
Got to be real careful with those airbags etc and follow all the safety proceedures including the Battery disconnected for 5 mins before disconnecting or testing anything.
_diagnostics - SRS.pdf
Many thanks for the attached files. I have diagnosed it as a faulty airbag sensor assembly center. So basically, the main control module.
Can i buy one of these seperately or do I require all of the airbags as well? In addition, is it a case of disconnecting the Battery, un-installing the original and re-installing the replacement?
Thanks again :)
Mikeyb123
Afraid have no idea, never worked on the airbags and that pdf was one I found online.
You might want to check with your local Toyota dealer first as to the new price for that part - not cheap I would guess.
Hope someone else may come in and answer your questions....
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
