Hilux Surf Opening The Tailgate
Tazbm
Doesn't look like too many people read the specific surf club so I'll try here
Looking at buying a hilux surf but can anyone tell me how the boot opens from the outside?
I can see the lock and handle inside but nothing outside. Clues please😊
Are you sure the rear window winds down fully? When the window is fully wound down the tailgate latch should pop up.
Thanks for responding.
I'll check when I test drive tomorrow.
Does this mean you can only open it from the inside?
Think there is a mechanism in the tailgate that prevents the tailgate from being opened until the window is fully retracted - otherwise the window risks being broken. If the window isn't fully retracting, the window winding motor may be at fault. I believe the motor is a common component with some other Toyota models of that era.
