afternoon all
I need to change my o2 sensor on the 2005 t sport I have, as its raining and I do not have a garage il be doing it in the next few days. so before hand I thought id do a little research,
has anyone got a picture showing its location?
or any advice before I start?
thanks in advance
monty
Don't know its exact location on the Tsport, but typically its on the manifold between the engine and the cat, very obvious by the cable coming off it.
From my limited hands on experience of Toyota 02 sensors -
Be sure that is the cause of your actual problem.
Carefully soak the thread in penetrating fluild a few times , overnight, before trying to remove.
Trying to clean a sensor is said to likely total it.
If using a second hand or new non genuine Toyota part, you have a chance of more problems than you had before.
Some models have 2 02 sensors ? one before and one after the cat, does yours ?
Again fairly obvious if you look at the exhaust pipe after the cat.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
