Oil Pressure
concorde
i have a 2001 rav 4 with a 1AZ-FE engine what should the oil pressure gauge read on tick over?
thank you
I have a sheet with some data on it looks like at 3000rpm and engine temperature normal running temperature 3.0-5.5 kgf/cm2 or 43-78 psi hopefully picture of sheet attached.
Have a look at picture see if you can work it out!
post-124631-0-75245200-1452119328_thumb.
