Generation 5 Tail Lights
jimjam190745
does anybody know how to remedy tail light problem.
I have all working lights but no tail lights.
Have changed fuse and bulbs to no avail. brake lights work ok as do the plate lights which is confusing me even more.
Any help on this would be eternally grateful as been trying to solve this for 2 days.
  • 2 months later...
Hi can you tell me how you changed the fuse for the tail lights? I have the same problem and I'm trying to find out how to change the fuse for the taillight.
Hiya
The fuse for the tail lights is on the drivers side footwear. If you get down where the pedals are, look to the left of the pedals and there should be a black plastic box cover. Prise off that cover and the fuse is near the bottom . It's a 15 amp fuse which I think is situated  under a couple of relays.
Good luck. I still haven't worked mine out yet and my fuse was fine.
