I have just replaced the break lines in the twin cam. It seems they have an issue with the master cylinder failing once the system is emptied. I have searched high and low for a new one but can only find one on eBay for a LHD. The problem is the LHD pipes come in on the wrong side and there is not enough room between it and the wheel arch to fit a new pipe, the only way is to drill 2 holes in the arch for the pipe to go out into the wheel arch and back in again to line up with the cylinder. Obviously this is not an option I want to even consider but it's lookin like I have not many options outside this. I have tried a second hand cylinder from a scrap yard that I can vouch was perfect working before removing, and it won't breat without pumping the peddle.
I need a new one :-( .
Is there maybe another model toyota part or any other make for that matter that will suit?
Any help on this issue will be greatly appreciated!!
Thanks for looking.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
