Connecting An Mp3 Player
Sussexlad
I've just bought a 2012 1.33 YYT-i SR
There's a suggestion in the handbook that there's an AUX input of some kind usb/aux ??
The siting of this varies from model to model ! Well I can't find it, :-(
Does this mean there's only bluetooth on the car? Bit of a pain if so.
TIA
See your other post regarding the owner's manual - if one downloads the e-manual, that should state whether one has an AUX socket and where it can be found.
On a 2012 Yaris SR with Touch screen the Aux/USB input is rather awkwardly located in the upper left corner of the glove box, open the glove box stoop down and look up to the LHS and you will see the inputs.
Many thanks for that. I'll get my torch out ! ;-)
Seems I may be running an AUX cable through the car if this is the case. I imagine this is the same on a 2012 1.33 VVT-i TR?
