2010 Lc3 Tyres Can I Fit..
fatgazzer
265 65 17s at present its fitted with 245 45 17s.
I know this will affect the gearing but am I right in assuming the engine (3.0 D4D) will have enough torque to overcome this, I will be towing.
I'm also assuming the height / ground clearance will also increase.
Gaz
You need to use a tyre calculator to see what effect the change will have on your speedometer. In the UK it is illegal for a speedometer to under-read (show less than the actual speed).
Using this calculator - http://www.autopartuk.com/tyre-calculator/
your speedometer will under-read by 19.5%, and read 60mph when you're travelling at 71.7mph, so will be illegal.
Thanks for that
But if the other versions use this size tyres there must be a re-calibration of some sort available?
Cheers Gaz
Yes there would be - just pointing out that the current calibration won't be legal.
Thanks Mike
Just done a calibration test, sort of, against my sat nav and the speedo is reading about 8% high. Its reading 70 at 65 mph, so I may just scrape in under the 10% leeway depending on which brand of course.
Then there's always a slightly smaller tyre 255's ??
Cheers Gaz
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
