Hi guys, so i just changed my discs and pads on my 03 1.6vvti Corolla e12 , and basically the rubber bellow on the front and rear Slider bolts has been damaged and needs replacing. Does anyone know where i could get them from other than eBay? Also does anyone know if the brake calipers on these e12 UK based Corollas are Lucas or Aisin? Thanks [emoji3]
Sent from my SM-G900F using Tapatalk
Have bought parts from this place ok, direct or via eBay.
To be sure about the caliper type you need to look for the stamp marks on the main body of the caliper, if you can see Toyota TRW then its Lucas - TRW /Lucas one and the same.
Have bought parts from this place ok, direct or via ebay.
Thanks, i spotted these which seem good but they only have listing for the front end, i need rear ones also, do you think they will have them if i contact them direct? Did yours fit on fine?
http://www.toyotaownersclub.com/forums/topic/169198-brake-slider-pins-location/
As far as I know the bellows rubbers are the same , back and front, though the actual pins are shorter at the back.
The bellows rubbers fit ok, though I did get one set of of their rear
slider pins but was not happy with their shape / fit so retained the
originals after swapping the rubber on the end of the pin over.
Don't make the mistake I once made and get the pin positions mixed up as they
will cause uneven pad wear and use red or silicone grease on the pins /rubbers .
Sorry so did you use the rubber bellows from the rear slider kit for your rear slider pins? or did you use the rubber bellows from the kit you sent me a image of for the rear slider pins also?
Im just asking because in the eBay listing for the rubber bellows you sent me, it suggest they are for the front :-S so just a little confused to whether i should just buy a set of the rubber bellows or i should buy the rear kit as well?
I only need the rubber bellows for passenger side front and rear.
Just looked at the old front bellows and the new rear bellows that I did not use and they do look like the pics below, though they both compress and stretch to the same distances.
Without actually trying them on the pins on the brakes, I could not say for certain, if that kit of 4 will fit both front and back.
Best to speak to them to see if they do fit or you need specifiy ones for front or rear , plus try your local Tototota dealer, they might also sell just the bellows.
post-95973-0-21532800-1453031473_thumb.j
post-95973-0-51822700-1453031482_thumb.j
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
