Hi does anyone know if the 2.0 Corolla D4D T3 2005 has a clock I have the screen without the hour and minute buttons and have took the fascia off and there's no circuit board behind either. I contacted a breakers yard for a replacement and theirs was the same. Is it possible to buy a clock and connect it up there seems to be lose connectors I could use.
As far as i know clocks were only fitted in lower spec models which didn't have a radio unit. I could be wrong be I believe all corollas in the uk had a factory fitted radio so it will probably be hard to find one in a breakers with a clock. I recall seeing a post about the wiring in this forum before.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
