Yaris 2013 Door Panel Removal
Dominic_Star
I need to get the door panel off of our frount Driver side door in order to replace the wing mirror assy. I looked at as many threads as I can and am not sure if I have the complete answer as they are nearly all for older models. In this thread it says there is a screw inside the door handle, which I can see and two behind the arm rest cover:
Is it pretty much the same on the front, but that they are under the electric window slots like this on the 2012 model pic in that thread? I can see the two screws behind that, but just worry in case there are any others? The cushioned panel next to where the electric window switches are, is much tighter and I can't find anywhere if I am meant to get that off. There is a tiny gap to get a priser or screwdriver once you get the cover for the window switches off, but it feels much tighter attached and I am scared off damaging it.
Thanks in advance for any help.
