Blade Master replacement emblem
MasterG
Hi Guys,
I've got a Blade Master and am having a bit of trouble finding a replacement front grille emblem for the current JDM symbol. I'm looking for the standard Toyota "T".
I think I've found a part number for the actual emblem itself that is the right size:
parts code 75741E
parts no 90975-02086
But that leaves me needing some form of base to attach it to and clip into the grille.
Does anyone know how I find a base that will fit? I've attached a photo of the current emblem to show what I need. I'm in NZ so if I can confirm what I need I'll see if I can find it locally.
Cheers
Matt :-)
The part number you give is the tailgate Badge on a Blade plus a few other models. The front Badge comes as a complete unit only on a Blade and there is no Toyota Emblem for a Blade, the similar European Auris & Australian Corolla have a different set up where the Badge is separate and the grill forms the backing on most models so they wont fit. There are a few options on Auris/corolla which may fit but it will be a trial and error process to find one that fits see: http://www.ebay.co.uk/itm/Genuine-New-TOYOTA-AURIS-FRONT-GRILLE-BADGE-2007-2010-Hybrid-Sport-VVT-i-D-4D-/301762058676?fits=Model%3AAuris&hash=item46426b99b4:m:m6LtbY_GSFu3wskpvlzbnDA
  • 3 years later...
