Prius
MikeS5762
I'm considering replacing my '07 T3 with a 2015 version.  With my side mirrors folded in the car has around 6-7 inches space per side to fit into the entrance of my garage. Once inside plenty of space .
Question:  Where/how can I access width dimension specs with mirrors folded or opened. I'm trying to avoid having to drive a newer car to to my garage for a test fit.
. My local dealer can't be bothered to actually measure up.
many thanks
the manual say 1745mm wide but I presume* that is with mirrors open. https://myportalcontent.toyota-europe.com/Manuals/Toyota/PRIUS_OM_OM47A19E_(EE).pdf
If you want it with mirrors folded you may have to go find a car & feed a tape measure across them through open windows.
*wrongly as it turns out, it is body width not incl. mirrors
Re Heidfirst's comments; that's what I was afraid of. My local dealer being 15-20 miles away.
Thanks for the replies.
MikeS
Do you mean 2015 Gen 3 model as opposed to the new 2016?
If the former, this might help:
http://biwel.com/pmb01/Gen 3 Prius dimensions.jpg
With the mirrors folded they stick out about 25mm per side more than the wheel arches, so I'd say 1745 + 50 = 1795mm (5' 11")
