2013 Toyota Yaris Alternator Wiring Harness
Tylervanpool
Hello,
My Battery light is showing on my dash indicator and the Toyota dealership is saying that their test came back showing that I have no charging amperage coming from my alternator to my Battery. My alternator is stock but brand new. I personally think there is a problem with voltage going to the alternator through the alternator harness and not telling the alternator to turn on or to charge the Battery. Could someone please tell me what each of the 4 wires does that are leading into the harness? I want to test each one with a micrometer but don't want to go probing around on wires I don't need to mess with. I think there is a Yellow/black stripe, black, green, and a blue.
Test it by yourself. Start engine then discount the Battery ground. If car stopped so alternator or its cable to battry is bad. If the engine continue and not stop the eltenator is good
Sent from my iPhone using Tapatalk
6 hours ago, dohsh77 said:
Test it by yourself. Start engine then discount the battery ground. If car stopped so alternator or its cable to battry is bad. If the engine continue and not stop the eltenator is good
I disagree, firstly you risk damaging the charging system by disconnecting the Battery on any modern vehicle with a smart charging system. In addition to this, smart charging systems do not constantly charge, so disconnecting the Battery and the car cutting out doesn't prove anything to be honest.
