Yaris Sat Nav TNS200
tomh15
I have a toyota yaris 05 colour collection with a navigation option on the stereo, is it just as simple as buying a tns200 navigation cd and putting it in a play? or do i need to check my yaris is compatible? if so how do i know if its compatible?
Many thanks
The headunit is nav compatible, TNS200 ( replaced by TNS300 ) is a turn by turn nav kit see: http://www.toyota-tech.eu/aimuploads/%7B1BAF382A-578F-0416-B20B-43569B3A578F%7D/TNS300%20RHD%20N3RP1W-2-0%2008545-52800.pdf
but it is very out of date, very limited in function and expensive you'd be far better served by a cheap tomtom or the similar.
So if I'm correct I can put the tns200 cd in and it will work without any further configurations?
is there a guide for tns 200?
thanks again
in other words where do I insert the tns200 cd? Does it go where regular music CDs go in the front or is there another location that it get inserted if so where?
thanks
Do you have the navigation computer/cd drive under the front passenger seat ?( see link to fitting instructions in last post ) if yes then a new CD will work otherwise you will to fit the kit
I thought of doing the installation 6 years ago  but frankly the cost and hassle for a pretty small screen looked a PIA. Bought a Garmin instead.
