toyota avensis t3-s d4d 53 plate estate
jem555
hi my heater is not very warm car drives fine could it be the thermostat neading replaced
Hi jem555,
Does your engine get up to temperature, if it does then the thermostat is fine. if it doesnt it could mean that it is stuck open which means that the pipe carrying hot water to the matrix are actually not that hot. (thats if i have correctly understood by thermostat).
Also you might want to search the forum. For example, look at
Regards,
Waqar
