2005 d-4d oil?
bobtabatha
Hi all
New to Toyota and am still poking my way round the forum:) I desperately need to do an oil change on the car which is a 2005 Rav4.2 (no DPF I believe). As it hasn't been done in  while will do a few shorter interval changes probably. Was wondering if this would be ok (it's ACEA B5 spec semi synthetic)
http://www.eurocarparts.com/ecp/c/Toyota_Rav-4_2.0_2005/p/car-accessories/engineoils/engine-oils-and-car-fluids/5w30-engine-oil/?521776022&0&3b85b0bb649f9961751e12f91c12c0a7f92125fc&cc5_247
Many thanks for the help:)
Once I've serviced it completely I may have a question about a slight hesitation around 2250rpm (need to discount dirty fuel filter or MAF/MAP first)
If it hasn't got a DPF it should be OK.
don't think it has one, at least there's no referance to it in the hand book
should have also said, thanks for the help:)
