Hi does any one know how to input the radio code for my corola verso 2007 radio cd sat nav after Battery disconnected.
its an all in one touch screen have tried google but all ones shown have preset buttons 1 to 6.
All that is on screen now is  please insert correct disc i cant even switch screen off.
Any ideas?
Do you have the codes in the manual? I would think the instructions for inputting the codes would be in the manual, but I'm not sure if it is even a code problem. My 2012 Toyota Touch system doesn't seem to use a code.
My 2005 Avensis didn't need a code either, it just worked again after re-connecting, but I had to re-programme the radio stations.
The nav unit doesn't have a code the message is asking you to insert a recognised navigation disc, open the screen and insert a nav disc into the slot marked "nav" the unit should then boot up, if there is already a disc in there take it out and give it a clean, otherwise you may have a faulty laser on the nav disc reader.
