Had a quick search and couldn't find anything on this :laugh:
I've now had the Aygo 2 months and I'm forever leaving the lights off!!
Followed another today and he/she didnt realise either
Any tips? (apart from the obvious)
TIA
One could always get into the practice of having headlights on all the time .....
Does your profile need changing?
Not any more :)
I just put them on when it starts getting dusk/dark? Not hard to remember after years of driving.
Any tips?
Dim the dash lights, thus it will dim every time you put the lights on.
Ah, wasn't aware you could do that....time to dig out the manual again....Thanks
Isobel, its the LED driving lights that do it, they are way too bright and it looks just like you have your lights on!!
Then again, the daylight running lights need to be bright to counter daylight and be readily visible.
They are way too bright. Way brighter than the sidelights which render them useless as well :blink:
ah yes I see now, I've got the old mk1 2014 aygo which still has the old dash board unlit lol
yep I've often decided when driving in dusk conditions that they're just as good as my side lights. But they still don't work on some drivers.
Legally daylight running lights should turn off when the sidelights/headlights are turned on, and it is recommended to use dipped headlights in built up areas at night.
But DRL's are only at the front, you need sidelights/headlghts on for the tail lights.
Yeah, i appreciate that...
I think the problem I have is living right in the middle of a city with loads of light pollution. I actually followed another Aygo yesterday with it's lights off which prompted this post
Need to read the manual again later as my first attempt only allowed me to lower the dash lights with the lights on
Ideal solution would be low level dash which gets considerably brighter with the lights on
You're correct that you can only dim the dash when the lights are on.  Personally I don't like bright dash lights at night, so I have mine dimmed when the lights are on.
