Yaris 2005 Colour Collection Rear Speakers
tomh15
I have a toyota yaris 2005 colour collection and I would like to install some Speakers in the rear as currently it only has 2 in the front on the dash and two in the door, do you know where i can get the wiring loom from so i can connect an extra 2 Speakers to the unit?
Many Thanks :biggrin:
Tom
15 hours ago, tomh15 said:
Thanks for getting back to me regarding installing speakers, I'm looking at buying these speakers http://www.ebay.co.uk/itm/BOSS-400W-TOTAL-BOX-TYPE-SHELF-REAR-DECK-CAR-VAN-CARAVAN-BOAT-POD-SPEAKERS-NEW-/191683250735?hash=item2ca1364a2f:g:kKsAAOSwu4BV6w0d , how would i wire them in?
do i need a certain cable?
No disrespect, but if you're asking these basic questions then I'd be getting a professional to do it. The last thing you want to do is blow things etc.
I am more than capable of doing it but I just need to know where I can buy the wiring loom from/ part number!
the site is here for a reason and I'm just enquiring where I would get the part number!
Toyota are the only people that would make/made a dedicated harness and both part numbers are contained with the instructions given, but two things to note:
1. Toyota part was a kit the main part # PZ426-P0240-00 Contained the Speakers, grilles, fittings and dedicated harness from front to rear then depending on how many Speakers the car originally had there was an additional adapter harness the fit behind the radio to connect into the to new rear speaker harness, for your car with 4 standard Speakers the adapter was PZ417-B0240-60, beyond these two numbers there are no other part numbers available.
2. These accessories only fit an old model the newest of which are now over 11 years old and chances of the Toyota kit being available still is slim to nil.
Without the dedicated harness you will have to strip out the radio and work out which terminals are for the rear speakers and wire in your own harness.
