Stereo from t27 in a t25
Andersgj
Will a dab unit from a 2010 t27 fit in a 2004 t25?
Will the steering wheel controls, light and so on work ok. Will the fascia plate fit?
Anders
There is only one radio type from a T27 Avensis that would fit into a T25 this is the TNS510 model which doesn't have DAB as standard but can have an additional module to add DAB.
The TNS510 is a standard double din size and would need an adapter to fit into the T25, it was not listed as an option on T25's so may require some wiring work to make it operate and may not work with steering controls
