Hi
I have a 2003 tsport which had been running perfectly until today.
On the commute home, I hit a wooden block (brick size) on the road. Was moving fairly fast so hit it hard - make a load bang....
VSC warning light came on and seemed to loose throttle ... pulled over and  switched off the engine....
Now the car will not start. It turns over fine, there is no obvious signs of damage underneath the car or in engine bay. No warning lights on the dash....
It just wont start......
Any ideas ?
Does your car have an inertia crash switch which turns off the fuel pump in the event of a sufficiently large impact?
Thanks. It turned out to be a relay and fuse had blown. not sure why but its back working now .... good for another 200k :laugh:
