Hello (European=Turkish NMTB Corolla 1.4 ZZE120L Terra sedan, mfg:2002)
Is there a hex bolt or such in the front light housing so I can adjust the front lights horizontally ? (Or do I have to bend the sheet metal ?)
I have this far found only VERTICAL ADJUSTMENT= In the middle there is a 8mm hex-plastic bolt and It is connected to the inside electric switch.
If your adjuster look like this , seems thats the only adjustment.
Other models do have both  vertical and horizontal adjusters located on top  of the units
Whats changed your horizontal angle ?
Bump to the front left fender... Someone fixed it poorly in 2007 and now it is my problem :sad:
Picture shows how the light beam looks now...
Toyota Corolla e120: 2002-2007
I found out this myself... Nobody seemed to know this ??? HUH ??? Corolla is one of the most common cars around in the world.
Here is a guide picture below to adjust the lamps manually....
