O2 oxygen sensor info
Gower Boy
Has anyone got the proper information on which Make, Type, and price to pay for the correct sensor for Bank 2 sensor 2, after showing a P0141 code, 2ltr petrol, 2002 Auto, Seems that NKG, Denso, or Bosh, are all possibilities, but have heard that fitting the wrong make or even a universal one can still cause problems, Would appreciate any info, thanks in advance 👍
I have fitted denso ones on mine and were fine. I would pay a little extra for a denso one with the correct plug already fitted then easy change. Some of the cheaper ones with no plug I personally wouldn't bother with. Should be able to get one for around £70 . I think bank2 sensor 2 is the bottom sensor on left standing in front looking at engine . It has a longer cable , measure cable and get one same length with plug fitted. You will need a proper sensor socket which has a cut out for the cable or use a spanner if you can but will be tight, get car nice and warm first but mind you don't burn yourself.
Thanks grumpy stumpy, sounds the business, think your right regarding the plugs, good man, 😀👍
