Prius T3 - 2015 - Audio setup
michaels5762
I'm trying to setup the Sound Settings under Audio Settings in the Touch Screen manual.
Problem:  I select Setup > Audio >  and the manual says/shows: Select Sound Settings  or Radio Settings. The screen in my car shows only Radio Settings tab to be selected. No Sound Settings tab.
Where am I going wrong?
MikeS
make sure the audio is switched on - you should then be able to get into setting for base/middle/treble & balance/fader.
All sorted. What a Tw*t I am.  Many thanks.
