Avensis T180 fault codes
Mr_Luv_Toyota
Hi all ☺
The T180 was doing fine until recently every morning guaranteed on my 1 mile trip in the morning to drop the kids off to school it cuts out into limp mode about 5 to 7 times, start it back up fine for a little bit then limp mode again, until the engine gets a little warm then it goes away.
Once the engine is fully warm it rarely happens but if it does its just the once only.
Also i notice it feels like its missing when im driving around time not constant though but it does, also it makes a bit like a cllatter sometimes under hard acceleration.
Anyways i had the eml checked and it brought up two codes.
One of the codes is a a P0093 large leak detected, the guy checking it says its the fuel rail pressure sensor but looking on here that code refers to a number of things ???
Second code is P0069 which he says is the intake manifold/air pressure sensor which may be coming up because of the fuel pressure sensor ???
I really cant afford to waste money and was wondering if anyone has expierienced something similar.
