Hi all ,
    I`m looking for the small ally spacer between the front wiper arm and drive spline on girlfriends 04 Corolla and cant find anywhere so wonder if anyone can help please , garages have quoted her for full linkage kit at £160 + £60 fitting , I`m sure its a part that should be just a few quids and a few mins swap .  Its the bit that supports the drivers side wiper arm under straight under the arm and is alloy that has collapsed and the arm is waggling a bit as its not fully supported now even when the nut tightened , looks a bit like a sewing thimble with a hole through it .   Any help much appreciated and thanks in advance .
Picture may help
