Horn not working
Dannysconnect
Hi
I've got a 62 plate hybrid auris
The horn has stopped.working
I can't find the fuse.or relay.for the.horn
Does.this car have them for the horn? If.so can someone kindly Give me the location
Update
The horn is now working.
Using the powerprobe it was not earthed to the body(corrosion)
After cleaning the area the horn now works.
It uses a 12v supply feed to the connector
Still have no idea where the fuse is but it doesn't matter now it works
Well done Danny for getting that sorted and coming back on and closing out the post.
@ Wayne2015 Are you listening???????????? Get oot there and start scraping away the rusty bits and get that horn of yours working again. Sheesh, it takes a noob to keep some folk right aboot here! :biggrin: :biggrin::biggrin:
Under the dashboard on the driver's side.
What's a horn?
