d4d 2.0lt T25 2004 engine sounds 'tappety'
ADECROSS
d4d 2.0lt T25 2004 engine high revving when idle  and sounds 'tappety' when running
Has any one experienced this problem
Thanks Adecross
How's your oil level? The 1.8vvti was tappety.i filled up with oil an it went away?
All oil levels are OK
I have made a video on WhatsApp but I do not know how to send it to this site.
You can get your tappets (valve clearances or lash adjusters) adjusted but it's not a DIY project if you're not fairly experienced.
It doesn't sound too bad to me from what I can hear. It's a chain driven double OHC all-alloy engine, they always sound a bit "cammy"
Thank you all for your feedback.
I apologise for not sending a reply sooner but I have had internet problems.
It is has a 1CDFTV 2.0LT engine and it sounded like a tractor in the cabin. Someone suggested that I should flush the engine and refill.
I did this and it the improvement was quite noticeable.
Thanks once again for all your comments.
airbox intake pipe rattle? that's a common one for getting mistaken for exhaust or tappet noise
