voice recognition problem
James44
I have a problem with the voice recognition on my 2011 Avensis multimedia system. If I reinstall and Bluetooth link my phone, transfer my contacts and create voice tags, the voice recognition system will work fine. Even when I turn the system off, lock the car and return 15 minutes later, it works. But if it is longer, when I return, the voice recognition says the phone is not connected even though it is because I can manually select a contact on the multimedia screen and it will dial and I can speak via the system. It has been like this since I bought the car, about 18 months ago. And it is the same with another phone.
Any advice or suggestions which may help to overcome this issue would be appreciated.
Regards,
Jim
Edited by James44
slight change of info
